2002 Ford F150 02 Ford F-150 [Axle Damage on the right side
2002 FORD F-150
230,000 MILES • 6 CYL • 2WD • AUTOMATIC
AK4DA1ABV
Hello everyone!
My 02 Ford F-150's right axle is damaged and I was planning on fixing it myself. I was wondering how much that part will be (and where to find it) and which part number it will be?
Thanks for the help everyone!
P.S. The seal is broken and the oil leaks out. We already changed the bearing but the smell is still there? The autoshop says it is temporary and we should replace the axle entirely.
Mar 19, 2010 at 12:33 PM
  • 110,240 POSTS
First, I would recommend getting one from a salvage yard. I would estimate you could get one for under 100.00 based on where you live.
Also, if the new seal is leaking, replace it when you replace the axle. Chances are it is damaged.
Mar 20, 2010 at 4:58 PM
