HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Oil Pump
2002 Ford F-150
WADE PE
MEMBER
2002 FORD F-150
4 CYL
2WD
AUTOMATIC
140,000 MILES
Does the oil pump goes bad
Wednesday, December 19th, 2007 AT 6:54 PM
BLACKOP555
MECHANIC
Yes, like all moving parts will wear out and go bad. But if you change the oil regularly, you dont have to worry about it going out for a very long time!
Wednesday, December 19th, 2007 AT 7:55 PM
Please
login
or
register
to post a reply.
Related Oil Pump Content
F150 2002 Oil Plug On Oil Pump Cover
I Have A 2002 F150 And I Removed The Plug On The Oil Pump Cover Right Next To The Oil Filter. I Lost About A 1/4 Of A Quart Of Oil. Do I...
Asked by
todd.howden
3 IMAGES
2002
FORD F-150
VIDEO
Oil Pump and Pan Replacement
Instructional repair video
Where Is The Oil Pump Located
I Have A Jasper Motor And The Oil Pump Has Gone Out Oil Light Is On Constant No Pressure. While Driving Engine Light Came On...
Asked by
charann
1 ANSWER
2002
FORD F-150
No Oil Pumping In The Right Side Of The Engine
No Oil Pumping In The Right Side Of The Engine. New Oil Pump. New Timing Chain Starts Fine But No Oil Pumping
Asked by
icepro
1999
FORD F-150
Emissions Or Oil Pump Or ?
Driving At About 75 Miles, I Heard A Slight Brushing Noise, Turned Off Radio And Heater, Still Heard Noise And Then "check Gauges"...
Asked by
RO
2005
FORD F-150
2000 Ford F150 Oil Pump
When I First Start Up My Truck In The Morning, The Oil Pressure Gauge Will First Move To Its Normal Position. Then After About 5 Seconds...
Asked by
Michael9096
2000
FORD F-150
VIEW MORE
Change Engine Oil and Filter Ford Edge
Engine Oil Change and Filter Kia Forte
