2002 Ford F-150 Rattle in gear with ac on
BEAGLEMAN_123
Noises problem
2002 Ford F-150 6 cyl Two Wheel Drive Automatic
when the truck is ideling and placed in gear with the AC on there is a very loud rattle coming from the tensioner pulley. I have replaced the power steering pump, belt, tensioner pulley, idler pulley, and ac compressor clutch assembly. The noise will not stop. I am out of ideas on how to stop the noise but the tensioner pulley is visibly jumping and causing the rattle. Any ideas?
Oct 8, 2010 at 4:09 PM
  • 110,246 POSTS
Does this only happen with the AC on? Also, is the engine idle very low?
Oct 8, 2010 at 4:58 PM
BEAGLEMAN_123
it does only happen when the ac is on.... as far as the ideling it is normal....
Oct 8, 2010 at 5:05 PM
  • 110,246 POSTS
The only thing I can think of is the AC compressor may be starting to lock up placing excessive tension on the belt. I say this based on the fact you have replaced all of the components that control the belt.
Oct 9, 2010 at 6:04 AM
BEAGLEMAN_123
that is going to be my next attempt, I noticed a little play in the powersteering pump this morning so I exchanged it... after installation if the noise persists I am sure it is the compressor itself.... will update with results
Oct 9, 2010 at 6:51 AM
  • 110,246 POSTS
Let me know what you find. Something seems to be putting too much of a load on it.
Oct 9, 2010 at 4:02 PM
BEAGLEMAN_123
Double check with another store if you buy a belt from oreillys!!! After the replacement of tensioner pulley, idler pulley, air conditioner compressor, accumelater, power steering pump, and belt I still had the same problem. I started to dig a little deeper into my $900 worth of receipts and decided to double check all part numbers. Come to find out the belt that oreillys has listed for my truck is about 1/8in longer than what is required. This allowed just enough slack in the belt to allow the tensioner to bounce uncontrolably when the motor is in gear at idle but, a small enough difference to dismiss as a stretched belt which needs to be replaced on comparison. At this time I am infuriated with oreillys and will be there 1st thing in the morning to have a sit down with the manager.
Oct 10, 2010 at 3:15 PM
  • 110,246 POSTS
Wow! I can understand you frustration and demand they return the money and your old (good) parts. They won't have them because they return the core. Then, I would demand the money back.
Let me know how you make out.
Oct 11, 2010 at 4:06 AM
