Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Intake Manifold
Replace/Remove
2002 Ford F-150 Help
2002 FORD F-150
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFREY.R
MEMBER
1 POST
How can the cooling tube that comes mounted into the intake manifold be repaired or replaced, with out replacing the manifold.
Sep 25, 2010 at 12:10 PM
BILLYMAC
Experienced Mechanic
if it is not broke off in the intake you can solder braze or weld
Sep 27, 2010 at 10:21 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
