Find the vacuum line that comes out of the firewall, this is the supply line, and it goes to a small reserve tank in the engine compartment or under the dash, then another line goes from the tank to a check valve, then to manifold. If the reserve tank cracks, or the supply line breaks, air will divert to the defrost vents when accelerating, or all the time. The reserve tank supplies needed vacuum to A/C system during these times!
Aug 2, 2008 at 11:05 AM
