2001 Ford F150 water under oil cap
HABKOUK
2001 Ford F150 V8 Four Wheel Drive Automatic
when i check under my oil cap i found a cream oil build up under my cap cleaned it of and found it came back again i could not find any oil in my coolent or in the oil when i draied it what is causeing this creamy oil engine runs great but it really bothers me my experiance tells me that it is a blown head but no other sign to conferm this please give me your opinion
thanks
joe
Jan 18, 2009 at 4:16 AM
BLACKOP555
  • 10,386 POSTS
its either condensation or its as you say coolant from a cracked head, block or headgasket.
you can try and taste it and spit it out, if its sweet its antifreeze.
you can perform a compression test to see what it is also
or you can use additives and special paper to see if theres combustion gasses present in the antifreeze.
Jan 28, 2009 at 2:01 PM
