2001 Ford F150 Using Oil
2001 FORD F-150
106,000 MILES • V8 • 4WD • AUTOMATIC
JUANHENLER
My Triton engine has been using oil. 2 Quarts between changes. Most of the time it does not smoke but once in a while when you push on the gas hard it does not pick up speed and lets out a big cloud of smoke. Then it will gather speed and no smoke. Can it be anything besides bad rings that will cause this.
Jul 29, 2010 at 11:59 AM
Hi juanhenler, Welcome to 2carpros and TY for the donation
Sounds more like an uipper end problem with the valvetrain such as valves/guides/seals-get a valve job-A ring problem will be always there accelerating or decelerating-
Jul 29, 2010 at 12:06 PM
