bearing hub?
10,500 MILES • V8 • 2WD • AUTOMATIC
FINGERS3
when making a left turn there is a growling sound. i have put the truck on a rack, tried to move the wheel, like checking a front wheel bearing, don't see any grease. this noise has increased during the last month.
Jan 27, 2008 at 11:57 PM
MIKE H R
  • 3,094 POSTS
put the truck on a rack, check the rear end fluid. you should be able to touch it with your little finger in the hole. after you get some fluid on your finger rub that finger and another together see if there is any gritty feeling, the rear diferental fluid lubricates the bearings. if the fluid is low add correct differntal fluid, the rear bearing could be going bad.
Jan 28, 2008 at 12:29 AM
DADS68
I had the same problem. Seems the axle wasn't heat treated right. The race from the bearing wore the axle. I had to replace it. Mine started to vibrate after the grinding noise started
Jan 30, 2008 at 5:33 AM
FINGERS3
after checking the lub and finding no metal shavings we changed over to bgls2 additive with the thought that this would clean the "clutches". it worked, no need to r&r seals.
Jan 31, 2008 at 10:58 PM
MIKE H R
  • 3,094 POSTS
Keep an eye on the drive shaft, my wife has a 2003 and the driveshaft was enclosed, what we found was that it had never been lubed when put together. She had rear end noises and they ended up replacing the whole rear end along with the drivshaft.
Feb 2, 2008 at 2:14 AM
