I have noticed in cold weather when I first start my truck it has very little oil pressure. After it warms up a bit the pressure jumps up to normal for a few seconds then back to almost nothing and then will jump up to normal and stay there. This did not happen in normal temps (10 degrees and above).
The oil I am using is 10w - 30. Is that to heavy an oil for the sub zero temps.
Thanks.
Thanks.
Jan 21, 2008 at 12:21 AM
