2001 Ford F150 need help!
2001 FORD F-150
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAMSTONE
So I'm driving to base to go take a test. I notice that my battery light is on. I also notice that the farther I drive, the power meeter starts to go down to nothing. It shows on the meter that there is no energy in my battery. I park and cut off the engine. Then I go and take my test and come back a couple of hours later. I put the key in and it starts up without any problem and the battery meter shows the battery at half full. I continue to drive down the road, I notice that the battery light is still on. Eventually the meter starts to go down showing that the battery is emptying. The trucks engine goes off and i loose power steering etc.... I pull into a parking lot.
That's where I'm at now. Not sure whether it's the alternator or a combination of things. Any suggestions are welcome.
Jun 25, 2008 at 8:37 AM
BMRFIXIT
  • 19,053 POSTS
I would say check the belt and fuse if all ok
you need a new alternator
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Jun 25, 2008 at 10:06 AM
