theft light blinks
2001 FORD F-150
111,540 MILES • 6 CYL • 2WD • AUTOMATIC
JACKSS
My F150 has an issue starting, when I begin to turn it over, the overdrive light turns on and the theft light in the dashboard blinks rapidly and the engine will struggle to turn on, I've found a way to overcome it by continually clicking the ignition back and forth until the light no longer comes on which lets me know it will start then. Do you happen to know what could be causing this? I've checked my fuses and they all seem to be fine.
Aug 19, 2010 at 7:30 AM
  • 110,244 POSTS
It sounds like the security system is locking things down. If the security light is flashing, that is where the problem is coming from. The bad part is the only people who have the equipment to properly test it is a dealer.
Aug 19, 2010 at 1:44 PM
