2001 Ford F150 Instement cluster
150,000 MILES • V8 • 4WD • AUTOMATIC
DETAILNY
On hard acceleration or if wheel spin in rain the cluster will peg all gauges and then all fall to bottom of scale. At the same time the battery light will come on as well as the ABS light. The speakers will also begin crackling if radio is on. Bring vehicle to a stop and cluster will reset, lights go out and all is good till next RPM increase. Sometimes only normal start from a stop will cause this. It will however only do this if in gear. You can sit in park or neutral and rev all you want and its fine.I have pulled the cluster thinking I have a bad connection. Resitance check of both connectors while plugged in showed all good connections. I have not been able to get my local ford dealer to let me look at factory wiring book to see what conection is between ABS, Bat., Trans, and radio circuts. Anyone seen this or can tell me if a module maybe sees input from all hese areas?
Aug 22, 2009 at 8:36 AM
BMRFIXIT
  • 19,053 POSTS
Since its only does it when its in gear I would suspect bad wiring and or ground that is moving with engine movement
check battery terminals and cables
check wiring harness by the firewall
check for a good ground at the engine
run a temp ground wire and secure at engine block
good luck
Aug 22, 2009 at 10:58 PM
MJR346
  • 132 POSTS
The sweeping gauges tell me the cluster is loosing power (it does this gauge check when power is put back on)
However with alternator light on, I'd check wiring going to alternator and from alternator to battery. the last part is the one I see most issues with as people use the aftermarket clamps which bolt together on the batteries and cause high resistance issues when the connections corrode or loosen up.
another thing is to check for dirty contacts on all connections underhood, and make sure no water issues hitting fuse box on inside
Aug 24, 2009 at 8:16 AM
