2001 Ford F150 ignition coil wires (location)
2001 FORD F-150
87,000 MILES • V8 • 4WD • AUTOMATIC
JAMESPEPPERDOG
As obvious as it sounds I cant find my plugs or coil wire to change one if you have a picture that would help. thanks
Jan 20, 2008 at 4:37 AM
FISHERMAN
  • 937 POSTS
[quote:e2ce466a61="jamespepperdog"]Other Category problem
2001 Ford F150 V8 Four Wheel Drive Automatic 87000 miles
As obvious as it sounds I cant find my plugs or coil wire to change one if you have a picture that would help. thanks[/quote:e2ce466a61]
4.6 or 5.0 ?
Looks like the coil its on top of the spark plug, your engine does not use spark plug wires.
good Luck!
Jan 20, 2008 at 6:32 AM
