2001 Ford F150 Idle rough, power Brakes don't work
136,000 MILES • V8 • 4WD • AUTOMATIC
RAPITUP
This truck started Idleing bad, plus the power brakes don't work. I check the pcv value replace the vacuum value on thr brake boster, check for vacuum leak(cant find any). I pull off the vacuum line from the boster and the motor runs better but stills misses there is lots of vacuum going to the boster when i put my finger over the line the motor wont ot stall.whit everthing hook-up the motor aks like it's not getting enough intake-air.????
Oct 15, 2008 at 1:47 AM
DOCFIXIT
  • 18,828 POSTS
Think diaphram in booster is bad or air valve. You may also have a rich fuel problem too.
Oct 15, 2008 at 10:26 AM
