2001 Ford F150 IDLE LOPE IN COLD TEMP
2001 FORD F-150
177,775 MILES • V8 • 4WD • AUTOMATIC
HAWKEYE60
T RUCK LOPES WHILE IDLING IN COLD WEATHER. CHANGED MAF SENSOR AND NEW PLUGS. HELPED BUT STILL LOPES NOT QUITE AS BAD . WHAT ELSE SHOULD I CHECK?
Feb 25, 2010 at 11:54 PM
  • 110,244 POSTS
Has the check engine light come on?
Feb 26, 2010 at 4:39 AM
HAWKEYE60
yes ,thats when i put new maf and plugs.there was a code of po174 and po171 from a.z.
Feb 26, 2010 at 6:31 AM
  • 110,244 POSTS
That is a lean mixture on both banks. Have you checked for vacuum leaks?
Feb 26, 2010 at 7:08 AM
