2001 Ford F150 fuel tank
141,000 MILES • 6 CYL • 2WD • MANUAL
BRENT70
My fuel pump is bad and I need to replace it. My fuel tank is half full and I can't find a way to drain it. I removed the metal pipe from the fill point down to the rubber hose that goes into the tank and I still can't get my siphoning hose to reach the gasoline. Is there any easy way to drain the tank?
Dec 28, 2007 at 3:00 PM
BLACKOP555
  • 10,386 POSTS
your best bet would be to block up the tank and drop it down one inch at a time.
you may also be able to siphon it out with a pump hooked on the fuel pump on the out line.
Dec 29, 2007 at 1:38 AM
