2001 Ford F150 fan not blowing air
2001 FORD F-150
17,500 MILES • V8 • 2WD • AUTOMATIC
BLKANDBLU
trying to figure out where the a/c fan relay in located and also where is a/c blower is and how hard is it to change, for a do-it-yourselfer........compensor turns on when knob is moved, but no air out of vents
Jun 25, 2008 at 5:30 AM
DOCFIXIT
  • 18,828 POSTS
Relay would be in a black box in engine compartment.
Blower behind glove box
Jun 25, 2008 at 6:01 AM
MERLIN2021
  • 17,250 POSTS
If you have auto temp control, check for power at the blower motor speed controller, if you have manual a/c do the same at the blower resitor, they are both in the a/c plenum, use a voltmeter, if there is power check the blower connecto for power, if there is power there replace the blower, if not and there is power at the resistor, replace resistor. If no power at resistor, check switch for power.
Jun 25, 2008 at 9:08 AM
