2001 Ford F150 F150 TRUCK
2001 FORD F-150
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
MS.BASS
WHAT IS THE SHIFT INTERLOCK CONTROL SYSTEM IS AND WHERE IS IT LOCATED.
Sep 15, 2009 at 10:52 AM
DONALDGOLDSR
  • 38 POSTS
[quote:f9f20411d4="MS.BASS"]2001 Ford F150 6 cyl Two Wheel Drive Automatic 140000 miles
WHAT IS THE SHIFT INTERLOCK CONTROL SYSTEM IS AND WHERE IS IT LOCATED.[/quote:f9f20411d4]
The shift interlock wont let you shift from park unless the brake pedal is depressed. If it is malfunctioning, the quick bypass is to turn the key almost to "off" and shift to neutral before starting the truck.
I think the switch is the same as the brake light switch on your brake pedal bar. Have you noticed your brake lights acting funny?
Sep 15, 2009 at 1:25 PM
