HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Trouble Codes
P Codes (Powertrain)
2001 Ford F-150 Engine code
TANGO
MEMBER
2001 FORD F-150
V8
FWD
AUTOMATIC
60,000 MILES
Cylinder 3 misfire detected mean
Wednesday, March 19th, 2008 AT 6:20 PM
BMRFIXIT
MECHANIC
PCM Monitor the engine operation
a misfire code indicate that cylinder not giving a 100%
cause and things to check :
spark plugs
wires
coil s
injector s
compression
CHECK IT FOR A TUNE UP !
Wednesday, March 19th, 2008 AT 9:22 PM
Please
login
or
register
to post a reply.
Related P Code Content
2004 Ford F150 P2100 P2107 & P2110 Engine Codes
Does Anyone Know If This Is A Problem That Will Be Covered By A Recall? While Looking Under The Hood For Evident Problems, I Notice What...
Asked by
Lu01eg
2004
FORD F-150
1995 Ford F-150 Diagonostics Codes
Computer Problem 1995 Ford F-150 V8 Four Wheel Drive Automatic I've Done A Diagonostics Code Check On The Engine The Code That Comes...
Asked by
mkeela
1995
FORD F-150
1990 Ford F150 How To Check Codes
We Need To Know How To Check The Engine Codes.
Asked by
lniecko
1 ANSWER
1990
FORD F-150
1986 Ford F-150 Obd-1 Scanning Issues
I Bought An Obd-1 Scanner Recently And Tried To Test My Truck, An Efi 1986 F-150. The Scanner Will Not Go In To Test Mode, Meaning It Will...
Asked by
SaleenS331
1 ANSWER
1986
FORD F-150
How to Read Codes
Check Engine Light
Is it Safe to Drive Check Engine Light?
