state inspection,inspector plugs his dba cord into your trucks system under dash,name of the plugor cord i dont know the correct term. used.? but when i plug a 20a fuse in the #3 spot in fuse panel and it pops time again.of the two power outlets one works ,the left side i belive it works the cig lighter,i use it daily a radar detecter.my question is there a right way of taken out the power ports so that i can see what may be the problem w/ the direct short or replace one of the power ports. thank you for your time,this may not be worth your time but again thanks,stevendb11
Jun 15, 2010 at 3:23 PM
