2001 Ford F150 ABS system
2001 FORD F-150
JFTWOOD1
Brakes problem
2001 Ford F150 V8 Four Wheel Drive 98000 miles
abs is ingaging at under 20 mph by itself.also makes noise like a pump sound.all at slow speeds.no abs light stays on when engine is on.mechanic plugged into obd and got no codes.recommended take to dealer.
Dec 8, 2008 at 4:15 AM
  • 110,244 POSTS
Hi:
It sounds like there is a bad sensor at one of the wheels. I too recomend taking it to a dealer to be checked. They will have the exact tools to properly check it.
Dec 12, 2008 at 8:05 AM
