2001 Ford F150 4x4 working
2001 FORD F-150
87,000 MILES • V8 • 4WD • AUTOMATIC
RAMGOD1
when i turn the selector switch to 4x4 you can hear and feel it engage but there is still no power to the front tires, the front drive shaft turns going into the front differential. any thoughts on what might be broke?
Sep 10, 2010 at 5:22 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile, Imma CJ Guy
I do not know your rig.....others who might know more, may jump in and tell you more.
You have a Decent description, but a little more detail might help me, or someone else to know where to start!
1st you say the driveshaft turns going into the diff.....if you have the transfer case locked in (like in 4X4) is the driveshaft "LOCKED" into the transfer case? (if engine off, + in 4X4, can you turn the front driveshaft?)
Next---the more involved test
Put in 4X4
Jack up the whole front......turn a front wheel, does the driveshaft turn?
Does the other wheel turn?
2 people--one on each wheelturn both does driveshaft turn?
With this info and knowing what should happen.
If you have a standard diff (NOT LIMITED SLIP)----if your front wheels are locked into your axle......in the air----one wheel will rotate the opposite direction of the other............with Limited slip, same direction
On my CJs, you lock in the MANUAL front wheel hubs.....the same is true...
BUT---(has happened w/ inexperienced passenger)
You tell them to lock their side inand they DO NOT DO IT COMPLETELY........I'm now shifted into 4X4, but my "UNLOCKED" axle spins freely--unseen inside the hubthe other wheel is non-powered because the differential transfers all power to the "SLIPPING AXLE"slipping wheel---broken axle.....whatever the case may be........Understand?
So your best scenerio here is:
Your Automatic locking hubs---one or both, may not be locking your axle on one or both sides----w/ a standard diff results are the same no power to either wheel......if you have power from the transfer case.
You might even get in close and MAYBE see if the wheel turns the axle....at the wheel where the axle goes in.
Worst may be something is broke, your testing will reveal transfer case or up front.
Your AUTOLOCKING HUBS.....may be dirty,....need greasing, other attention
Like I said, I do not know YOUR RIG......owners manual or a repair manual will probably tell you exactly what to do and how often!
If you use your imagination, like pretend a axle is not Attached to a wheel----like a hub NOT LOCKED, watch this video and YOU WILL UNDERSTAND what I am saying.
http://www.2carpros.com/articles/how-a-differential-works
Respond with good news!!!
The Medic
Sep 10, 2010 at 12:39 PM
