2001 Ford F150 01 Ford F150 Oil Light
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
01GREENF150
I have an '01 F150 w/ about 155k miles. Anytime the truck sits long enough to cool down, the oil light will come on and show no pressure upon startup. If I let the truck sit and idle, it usually goes off in about 5 minutes (same if I go ahead and drive).
Generally it will bounce from mid range pressure to zero pressure a couple of times before it goes off for good.
Generally this problem is lessened (but does not go away) right after an oil change.
Generally it drives perfect, even with the light on. When it's really cold (below freezing) the engine will actually bogg down and not accelerate strong. However, this will only last for a minute max. Once the truck gets warm it runs perfect...as good as the day I bought it.
The truck really runs perfect but I need to be sure I'm not destroying the motor. Any thoughts you have will be greatly appreciated.
Also, probably not related, but I will let you judge. When my undercarrage gets really wet (i.e. rain or carwash) I will get a missfire (and it's a loud, banging misfire that I can feel with my foot on the accellerator). Plugs & wires are all well connected and fairly new (30k miles).
In the rain, it is constant and can't get much above 40mph. After a carwash, it is less severe and goes away after a 10-15 mintues and the truck dries off.
Thanks for all you guys do.
Feb 2, 2009 at 2:15 PM
  • 75,988 POSTS
Do you hear any weird noises such as thudding and thumping at Park and Drive if not check the oil pressure with a mechancal gauge if normal replace the oil pressure sending unit, abnormal could be the oil pump sticking or engine bearings problem
Feb 2, 2009 at 2:45 PM
