2001 Ford F150
2001 FORD F-150
11,000 MILES • 6 CYL • 2WD • MANUAL
LILSQUIRT
i own a 2001 f-150 and the radiator support has rusted out along the bottom of the support where it mounts to frame rail. My question is........is this bracket a bolt-on assembly or is it welded?
Aug 24, 2010 at 11:39 AM
  • 110,244 POSTS
The upper part is welded and the bottom is bolted to the frame. Is it rusted at the bottom where bolted to the frame?
Also, just to let you know, basically the entire front end needs removed to replace it.
Aug 24, 2010 at 1:23 PM
LILSQUIRT
thanks for the info.
Aug 24, 2010 at 1:38 PM
  • 110,244 POSTS
You're welcome. Just so you know, the core support is around 600.00 and I think it calls for around 10 hours to replace. I have an expedition with the same problem.
Aug 24, 2010 at 3:58 PM
