2001 Ford F150
10,000 MILES • V8 • 2WD • AUTOMATIC
CINDY ARRIZOLA
it seems like the truck is idleing too low. It won't stay on unless you work with it for a while buy keeping your foot on the pedal. We have in the past changed the throttle postion sensor and that seem to help but now its not. Any ideas?
Sep 21, 2009 at 5:32 AM
  • 110,246 POSTS
HAs the check engine light come on? Have you checked for vacuum leaks?
Sep 21, 2009 at 6:49 AM
CINDY ARRIZOLA
no the check engine light has not come on and I have not checked for vacuum leaks. any suggestions how to check for leaks?
Sep 21, 2009 at 7:05 AM
  • 110,246 POSTS
Upen the hood and check for disconnected, damaged, or broken hoses. Sometimes with the engine running, you can hear a hissing sound.
Some people spray starting fluid on the hoses when it's running, but I don't like to because it can catch fire if you are not careful. If you choose to do that, be careful and if you hit a leak, the engine RPM's will increase.
Sep 21, 2009 at 1:38 PM
CINDY ARRIZOLA
we are going to check for leaks. This morning when I started the truck it die again and did not stay idle but I turned the heater on this time when I started it again and it stay on.
Sep 22, 2009 at 12:40 AM
  • 110,246 POSTS
Let me know what you find. Chances are the heater had nothing to do with it running.
Sep 22, 2009 at 12:53 AM
