2001 Ford F150
DEBBIE KAY
Tires and Wheels problem
2001 Ford F150
Tried to remove valve stem with the plastic cap of Slime and the plastic broke off inside the valve stem. How can I remove it? This is actually on a riding lawnmower wheel.
Jun 28, 2009 at 8:12 AM
BUDDYCRAIGG
  • 2,262 POSTS
start picking at it with a thick needle.
might even bend the tip of the needle a little to make kinda a hook shape
good luck
Jun 28, 2009 at 10:44 AM
DEBBIE KAY
I tried it with an ice pick but I will try a needle. Thank you!
Jun 28, 2009 at 4:33 PM
