2001 Ford F150
95,000 MILES • V8 • 2WD • AUTOMATIC
FRANK DOMINGUEZ
my transmission will stall or even shut my engine off when put into drive is scanned it for the codes and it shows p0743 sometimes it would run correctly and sometimes it will stall usually in the first few gears the code reads torque converterclutch electrical problem what should i do next
May 14, 2008 at 12:29 PM
  • 31,937 POSTS
Hi there,
This is something that you should really get a transmission specialist to inspect for you. I would do this ASAP before you do any damage to the transmission.
Mark (mhpautos)
May 14, 2008 at 12:33 PM
FASTEDDIE597
Sounds like something is causing the converter to lock up when you put it into drive. Might be Electrical. Get it checked.
Jun 12, 2008 at 3:11 PM
