2001 Ford F-150 Running lean on 1 and 2 with a miss on one
JWOOD60379
  • 2001 FORD F-150
  • 6 CYL
  • 200,000 MILES
4.2 motor engine light on code is running lean on 1 and 2 with a miss on 1. I have replace all of the 02 sencers, coil pack, fuel pump, throttle body sencer, Missesreal bad at 1500 rpm
Tuesday, November 2nd, 2010 AT 12:40 PM
WRENCHTECH
  • 20,761 POSTS
I assume you have PO171 and PO174. On Fords this is nearly always a severe vacuum leak. With the engine idling listen for a hissing noise and follow it to it's source. They are pretty notorious for sucking hole through the rubber connectors and hoses for the PCV and connecting lines.
Tuesday, November 2nd, 2010 AT 12:53 PM
