2001 Ford F-150 Loud Ticking Noise from front
THOMASSANCHEZ88
my truck has 91,000 miles on it and there is a loud ticking noise coming from the front area when the truck is in drive or reverse i have changed every tensioner and belt.
Nov 5, 2007 at 2:47 PM
FORDFAN
  • 9 POSTS
I had the same problem. does it sound like its coming from the side of the engine block? If it is its most likely your exhaust manifold gasket. You have to pull the headers for this to replace, which basically means the entire exhaust needs to be lose to do this. If not coming from the exhaust manifold area, then i would throw some BG oil in the sucker. You can go to any good auto parts store and ask them for the BG oil for ticking.
Nov 11, 2007 at 6:57 AM
