My husband tried going to work and the truck started but would not shift into gear. He went under the truck to unhook the linkage and try to manually put into gear and it would not budge. We are hoping it is a sensor that went bad. The only other thing is that his truck did not come with an owner's manual. He can not check the fuses to see if that could very well be the problem. What are your suggestions?
Jan 8, 2009 at 2:16 AM
