HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Drivetrain
Transfer Case
2000 Ford F-150 why wont my 4 wheel drive shifter Move
BMANN9234
MEMBER
2000 FORD F-150
6 CYL
4WD
MANUAL
228,000 MILES
I thank you for your time, why wont my 4 wheel drive shifter move ! Thank you
Friday, January 11th, 2008 AT 8:53 PM
BMRFIXIT
MECHANIC
The pivot bolt is rusted you need to remove it
and change the plastic sleeve
make sure you have to grease it good
on the outside under truck
good luck
SPONSORED LINKS
Friday, January 11th, 2008 AT 9:40 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
2000 Ford F150 Want New Truck
2000 Ford F150 V8 Four Wheel Drive Automatic Any Miles I Currently Have A 1984 Ford Bronco In Great Shape With 56997 Miles On It. I Am...
Asked by
james11
2000
FORD F-150
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1994 Ford F-150 4 Wheel Drive System.
This Is The First 4 Wheel Drive I Have Ever Owned. How To I Put It In 4 Wheel Drive And Take It Out?
Asked by
goodcook
1 ANSWER
1 IMAGE
1994
FORD F-150
1972 Ford 4 Wheel Drive - Need To Figure Out How To...
1972 Ford 4 Wheel Drive - Need To Figure Out How To Straighten Drivetrain.
Asked by
Kar623
1 IMAGE
1972
FORD F-150
1989 Ford F150 Won't Go In Gear
If My Truck Is In 2 Wheel Drive It Will Not Go In A Foward Gear. When Foer 4 Wheel Drive Is Engaged It Will Take Foward. Is The Problem In...
Asked by
plsp
1 ANSWER
1989
FORD F-150
1984 Ford F150 Eec Relay
Engine Mechanical Problem 1984 Ford F150 V8 Four Wheel Drive Automatic Can You Show Location Of Eec Relay, Having A Hard Time Finding...
Asked by
mace 59
1984
FORD F-150
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Rear Axle Seal Replacement
Wheel Bearing Hub Replacement
Online car repair manuals
