Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine Cooling
Water Pump
Replace/Remove
2000 Ford F150 water pump
2000 FORD F-150
133,000 MILES • V8 • 4WD • AUTOMATIC
GAGNE01
MEMBER
1 POST
i have the water pump unbolted, but it will not come out. Are they pressed in? I need any advise on how to remove the water pump.
Sep 21, 2008 at 3:51 PM
BMRFIXIT
Experienced Mechanic
Make sure you have removed all bolts and nuts
its not pressed in
tap it with a hammer should come off
Sep 21, 2008 at 11:46 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
