2000 Ford F150 STARTING
2000 FORD F-150
107,000 MILES • 6 CYL • 2WD • AUTOMATIC
WANTONO
MY 2000 F-150 WILL START SOMETIMES OTHER TIMES I HAVE TO PULL OFF AND PUSH ON THE SMALL WIRE ON THE STARTER RELAY THEN IT WILL START UP. ( THE CONNECTION IS TIGHT)
WHAT DO YOU THINK THE PROBLEM IS? THANKS.
Jun 21, 2010 at 12:44 PM
BLACKOP555
  • 10,386 POSTS
sounds like it could be internally damaged. you can put on a new wire and connector and see if that works better.
Jun 22, 2010 at 5:04 AM
