2000 Ford F150 shifting
94,000 MILES • V8 • 4WD • AUTOMATIC
JOE JENNE
Truck got wet and will not shift from 1st to 2nd...Help!
Nov 15, 2009 at 3:44 AM
  • 110,248 POSTS
How "wet" did it get?
Nov 16, 2009 at 2:07 PM
JOE JENNE
was on a two track, and went through a large puddle...Not a lake or pond, just a puddle. Did however bottom out, not bad though. Not even real sure that this is the cause. It's just the last thing that happened before the problem.
Nov 20, 2009 at 11:16 PM
  • 110,248 POSTS
If the trans fluid is full, chances are you have a bad shift solenoid. THey are in the trans under the filter. Has the check engine light come on?
Nov 21, 2009 at 3:21 AM
