yes you will need to remove the door panels. pop off the arm rest cover, then the cover that the door handle runs through. there is one screw under this cover you will need to remove. also you will need to pop off the molding that runs up the back side of the window. There is a screw under that piece of molding you will need to remove. Next lift the door panel and gelty pull panel away from door. You will need to disconect all the wireing that attaches to the door. Once you have removed the panel changeing the mirrors should be self explanitory. Good Luck
Jan 25, 2009 at 10:06 AM
