2000 Ford F150 Rear Brakes
14,000 MILES • 6 CYL • 2WD • MANUAL
RNSWILLIAMS
When I Am Moving Forward And I Hit A Bump Or Something Jars The Truck The Rear Brakes Lock Up A Bit I Can Feel The Drag. When I Back up it Releases What Do You Make of that. A mech. friend said it is an equalizer valve or something to that affect.....
Feb 19, 2009 at 4:58 AM
2CARPRO JACK
  • 11,533 POSTS
Drum or disc brakes on the rear of your truck? Discs could be a load proportioning valve, if drums, may need hardware or adjustment. Does it do this if you are off the brakes when you go over the bump?
Feb 19, 2009 at 5:33 AM
