Power steering pulley
CAROLANDRICK
  • 2000 FORD F-150
Trying to remove and install new power steering pully on a Ford F150 truck. Do I have to take off all the cowling and the fan blade to do this. I need detailed instructions.
Tuesday, May 19th, 2009 AT 4:57 PM
OBXAUTOMEDIC
  • 3,711 POSTS
I don't believe you will have enough room to do the R&R on the vehicle. You will need a P/S Puller (pic below) Puller and you need quite a bit of room to use it. So, I would remove the P/S Pump and do it on a bench or the tailgate.
https://www.2carpros.com/forum/automotive_pictures/188069_pulley_puller_2.jpg
Tuesday, May 19th, 2009 AT 7:41 PM
