2000 Ford F150 power door locks
2000 FORD F-150
206,000 MILES • V8 • 4WD • AUTOMATIC
KEIZERKEN
The power door locks in my F150 are not functioning properly. The power lock on the driver side works most of time, but the power lock on the passenger door does not. It moves sometimes, but sometimes not. If I work the switch on the driver side several times, then niether one will work. Acts like they aren't getting enough electricity. This just stared in the past few days. Ideas?
Apr 9, 2009 at 6:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
When you say the lock on the passenger side will not work at all, do you mean the lock is not functioning with any switch or do you mean that the passenger's switch is not working ? In any event, since this is an intermittent problem with the driver switch, I suggest inspecting the connections to the switch. If the connections are dirty or loose it will cause these symptoms. The passenger side switch may be completely dead and need replaced so try substiting a known good switch with it.
Thanks for using 2CarPros.com!
Apr 9, 2009 at 7:13 AM
