2000 Ford F150 no power to starter or solenoid switch
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
KATBU
I am getting no power from solenoid switch to starter. I replaced the solenoid and then replaced starter. I was told that the old starter solenoid was burnt out. When I installed new starter it crank once, and is doing same thing. there is a clicking like the starter is still engaged in flywheel while not firing at all. Im not getting any arc off solenoid at all.Also changed battery, checked fuses,and cant jump the truck off. any suggestions?
Jan 6, 2008 at 5:37 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a possible bad battery cable. Get a meter and check voltage at the starter, if not battery voltage, replace the cable.
Jan 9, 2008 at 11:34 PM
