HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Exterior Light
Running Light
2000 Ford F-150 lights
PIP1026
MEMBER
2000 FORD F-150
V8
2WD
AUTOMATIC
250,000 MILES
My lights exterior and interior on my 2000 F150 dim as I drive is there a solution?
Monday, December 29th, 2008 AT 11:08 AM
MECHANIC
Have you had the alt checked? It sounds like it isn't working properly.
Monday, December 29th, 2008 AT 11:37 AM
PIP1026
MEMBER
Thanks Joe, it actually turned out to be my battery.
Andy
Tuesday, December 30th, 2008 AT 8:18 AM
Please
login
or
register
to post a reply.
Related Running Light Content
Tail Lights Wont Turn Off
This Problem Affects Only The Red Part Of The Following Lights: The Tail Lights And The Outside Cab Light For The Truck Bed. First Of All...
Asked by
GJ26
10 IMAGES
2008
FORD F-150
VIDEO
Running Light Bulb Replacement - Front
Instructional repair video
GUIDE
Running Light Problems
The running light circuit is controlled electrically through a basic switch, BCM (body control module) or a LCM (lighting control module). These computer controllers are...
1998 Ford F-150 Left Rear Tail Light
I Put Every Thing New On The Left Side Flasher To Everything Else And Still No Blinker On The Left Side Everything Else Works
Asked by
hotrod990
1 ANSWER
4 IMAGES
1998
FORD F-150
1998 Ford F150 Daytime Running Lite
My Daytime Running Lites Will Not Shut Off
Asked by
grumpabeens
1 ANSWER
1998
FORD F-150
Turn Signal Light Added In Mirror?
My 2012 F150 Side Mirrors Does Not Have Turn Signal Lights. Can These Be Added In The Blank Spaces
Asked by
sandcay
4 IMAGES
2012
FORD F-150
Multifunction Switch Wire Diagram?
Where Can I Find A Wire Diagram That Lets Me Know Where Exactly The Wires Need To Go On A Multifunction Switch On The Steering Wheel. I...
Asked by
e777rodriguez
2 IMAGES
1999
FORD F-150
VIEW MORE
How to Use a Test Light
Turn Signals Blink Fast
