My Ford is leaking radiator fluid enough to need refilling the tank every couple of days(6 miles a day). it started on monday. It is definately not from a hose but off of the top right hand side of the block, appearing to be near the front head.
What do you think?
I had one mechanic tell me that you have to pull the entire engine to change the heads on this small 6 cyllinder(manual). Does that sound right??? 18 hours labor seems like an awful lot for a head job. Thank you for your input.
What do you think?
Dec 18, 2007 at 8:06 AM
