Noises problem
2000 Ford F150 6 cyl Two Wheel Drive 240000 miles
I need to remove the tension pulley for the fan belt and replace it as the bearing is bad. Even the spring seems to be stuck as a could not get the tension off
to remove the belt. The hole unit might need to be replaced. Thanks
Jan 19, 2010 at 1:07 AM
