2000 Ford F150 HEATER BLOWS COLD
2000 FORD F-150
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
UBASSFISHER
i have a 2000 ford f150 and wen i turn on my heater all it does is blow cold. even after driving 20 min. i have felt the lines going to the heater core and both are warm... any suggestions??? My a/c blows FREEZING cold like it should.
Dec 16, 2008 at 3:03 PM
Check the thermostat and heater core-
Dec 16, 2008 at 3:07 PM
UBASSFISHER
if it was the heater core wouldn't one of those lines be cold??
Dec 16, 2008 at 4:29 PM
When its partially clogged it 'll get hot on both side-try flushing it out-Have you check the thermostat ?
Dec 16, 2008 at 5:09 PM
UBASSFISHER
i replaced the thermostat not too long ago and my truck will heat up but not overheat so its not closed. and my heater doesnt get warm at all. so if it was partially clogged then it would atleast blow a lol warmth??
Dec 17, 2008 at 8:30 AM
Try running it w/o the thermostat and see what happens an open thermostat will not give you enough heat to get comfortable or to cause it to overheat
Dec 17, 2008 at 10:35 AM
UBASSFISHER
y??
Dec 17, 2008 at 4:14 PM
RONDA44
You might want to make sure your heater blend door is working properly. I had the same problem and finally figured out the door was not working and had to have it replaced. The dash will have to be removed for it to be fixed. Good luck.
Dec 28, 2008 at 10:26 AM
