What is the best wat to get rusted exhaust manifold studs out on a 2000 F150 Alum head. thanks
Jun 8, 2010 at 2:03 PM
BLACKOP555
✓Experienced Mechanic
run vehicle and get it hot and try. causes the aluminum to expand so the studs should come out pretty easy tighten them and loosen them. then put back in and wiat for engien to cool after they break loose before you remove them
