2000 Ford F150 Broken wheels studs
129,000 MILES • V8 • 2WD • AUTOMATIC
RODANDMARY
I'm replacing my wheel studs on the right rear. I have taken off the brake components and the old broken bolts are punched out. I don't have enough clearance to insert the new studs. Tried removing the rear shield, still don't have enough room. Any suggestions? Do I need to remove the hub flange? If so with what/how?
Aug 7, 2008 at 6:27 AM
BELLEVUE5150
  • 7 POSTS
You need to drain the rear axle and remove the axle shaft.
Aug 10, 2008 at 8:05 AM
