battery I grabbed was backwards?
124,000 MILES • V8 • 4WD • AUTOMATIC
MOOSEFBALL09
I hooked a different battery up to my truck to start it while the origanal was charging and I didn't relize that thhe battery I grabbed was backwards. I accidently hooked the negative to the positive and the positive to the negative. Now the batteries won't hold a charge and we tested the altenator and it's good what could be wrong? thanks!
Dec 8, 2007 at 5:31 AM
  • 75,988 POSTS
Welcome to 2carpros
You short circuited the battey-might also want to have the alternator load tested to make sure its putting out and inspect the fusible links.
Dec 8, 2007 at 5:41 AM
  • 55,694 POSTS
When you connect the batteries backward it can short the battery out internally and it will need to be replaced. Here is a guide to help you fix anything else that might be wrong.
https://www.2carpros.com/articles/resolving-reverse-battery-connection-in-cars-a-step-by-step-repair-guide
Jul 20, 2024 at 11:54 AM
