when I shift into 4H its not working it goes straight into 4L, the 4L works whether you have it in 4H or 4L, what could cause that, Thanks Rob
Aug 2, 2010 at 8:46 AM
MERLIN2021
✓Experienced Mechanic
Is this just while the truck is in motion? Or even at rest? I will tell you that the shift motor is often the problem, take it off an try cleaning the contacts, reinstall it, tap it with a small hammer, if 4X4 now works, down the road you will need the shift motor.
Aug 2, 2010 at 8:49 AM
ROBGOF
MEMBER
1 POST
Thanks for the reply back, it doesn't matter whether its moving or setting, & where is the shift motor located at, & again Thanks so much, Rob
Aug 2, 2010 at 9:08 AM
MERLIN2021
The shift motor is on the transfer case, it looks like a window motor... Have someone press the button while you tap it.
Aug 2, 2010 at 7:42 PM
