1999 Ford F-150 valves rattle
GORDONJ
  • 1999 FORD F-150
Noises problem
1999 Ford F150 V8 Four Wheel Drive Automatic
valves rattle when you start the truck. It then rattles every time it shifts from 1st to 2nd and 2nd to 3rd. It sounds like timing is too far advanced. Would it be a senser, also you here a knock by no-1 that sounds like wrist-pin or connecting rod. Milage is 235 k. Burns 1 litre of oil in 2 k.
Wednesday, September 1st, 2010 AT 8:52 AM
  • 109,885 POSTS
Has the check engine light come on? Do the valves only rattle at start up? Also, are you using a quality fuel?
Wednesday, September 1st, 2010 AT 10:43 AM
GORDONJ
Valves rattle at start=up. Fuel is regular. Also they rattle when it is shifting from 1st to 3rd. Also when cruising at 110 kph does not kick into passing gear.I have not checked any hoses or sensors. It is 120.00 to put on computer at our garages here and engine light is on. Went on 1 year ago when running daylight sensor shorted out. Disconnected sensor because price was 137. Oo for sensor which is ridiculas. Also thank-you for your quick reply. Gord
Wednesday, September 1st, 2010 AT 8:49 PM
  • 109,885 POSTS
If the rattle seems to be as you described, my first guess is a knock sensor. However, without having the computer scanned, that is a guess.
One time, you may want to try better gas. It may help. Also, since they charge so much to have it scanned, you should purchase an OBDII scanner. The basic ones are around 60.00.
Thursday, September 2nd, 2010 AT 6:54 AM
GORDONJ
I just gassed up with no 1 gas. Scanners run 2-300 hundred bucks here.I am going to canadian tire 200 miles away and I will post repley late next week.I am going up north to set up a bear-hunting camp. Thank-you for quick reply. Gord.
Friday, September 3rd, 2010 AT 6:05 AM
