1999 Ford F-150 Help
7DAFFODILS
  • 1999 FORD F-150
  • V8
  • 4WD
  • 10,000 MILES
Hi
I was backing up one day, and my wheels stopped. Like I could feel resistance, so I put it in Drive, pulled up a few feet, then back in Reverse. Same thing again. So I gave a little gas and 'pushed past' the resistance (just a few feet), and when I put it in drive, there was a noticeable 'rattle'. Like something is broken. I can put it in gear, no problems, just the rattle. Does this sound like a trasmission problem, or maybe the brakes? Expensive?
Thanks!
Tuesday, August 17th, 2010 AT 1:45 PM
  • 109,885 POSTS
Can you tell aprox where the noise is coming from?
Wednesday, August 18th, 2010 AT 8:06 PM
7DAFFODILS
Not exactly. It rattles when I put it in drive or reverse.
Thursday, August 19th, 2010 AT 1:47 AM
  • 109,885 POSTS
It sounds like it could be a heat shield on the exhaust. Take a rubber mallot and tap on the exhaust to see if you can duplicate the noise.
Let me know what you find.
Thursday, August 19th, 2010 AT 8:33 PM
7DAFFODILS
Hi
Finally got the truck fixed. Tow truck driver knew right away."Brakes".
The guy who fixed it, a Ford mechanic for 20 years, said he'd never seen anything like it. And can't figure out how it happened. (He thought maybe if it had been sitting for a really long time. But it hasn't)
He said he went to take the rear brakes apart, and everything just "fell to the ground. Destroyed".
So had to have everything replaced. And $850 later, she's back on the road.
Have you ever heard of this?
JoAnn
Monday, October 4th, 2010 AT 6:23 PM
  • 109,885 POSTS
I only saw that one other time and it was on a Chevy Tahoe. I never suspected that based on the description.
Regardless, I'm glad you got it fixed. Let us know if you have questions in the future.
Monday, October 4th, 2010 AT 10:12 PM
