1999 Ford F150 O.D. off light blinks
136,000 MILES • V8 • 4WD • AUTOMATIC
S.SMITH1966
My overdrive off light was blinking for about 1 month the stopped blinking. While it was blinking, when coming to a stoplight or stopping, the trans clunked when it down shifted from 2nd to 1st. Now it has stopped, but truck doesnt seem to shift into overdrive and stalls when braking to a stop at intersections or when just trying to get out of my drive way when I start my truck. It seems that it idles just below 1000rpm and really hesitates when accelerating at start. Any thoughts on whats happening? Thanks.
Nov 19, 2008 at 11:05 AM
RACEFAN966
  • 5,029 POSTS
Sounds like you need to replace the overdrive button on the end of the shifter. This can be bought at most parts stores. Also check fuse number 6 and number 15 (5amp fuses). Hope this helps you out.
Mar 24, 2021 at 3:21 AM
S.SMITH1966
Thanks! I will do that and hopefully it will work
